Posted Tue, 24 Apr 2018 15:01:20 GMT by Casey Miller Director of Technical Services
It is because you are using 64bit office installation. I would uninstall and install x86 office. DocuWare is not supported with 64bit office as far as I know.
Posted Tue, 24 Apr 2018 15:14:44 GMT by Joe Kaufman Bell Laboratories Inc No longer there
Casey,
I am using Outlook 2016, 64-bit, and C2O has worked for me. WHen I check the COM add-in, it even lists what appears to be a 64-bit loader DLL called "adxloader64".
I do not know what might be causing the original poster's issues, though, sorry...
Posted Tue, 24 Apr 2018 15:37:14 GMT by Joe Kaufman Bell Laboratories Inc No longer there
Hameed,
What is the target for the C2O configuration? That is, are you trying to store an email to a document tray or directly to a file cabinet?
Can you get any Store configuration to work?
I just tried again with 64-bit Outlook (I had deactivated the COM add-in) and was able to store an email to a document tray with no errors...
Posted Tue, 24 Apr 2018 16:23:36 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Hameed,
Please ensure the .NET 4.5.2 is installed. If it is uninstall it then re-install manually and reboot the machine.
Get Help
Chatbot Button
