Publicado Thu, 21 Mar 2019 17:56:32 GMT por David Blake Ricoh USA Sr. Solution Integrator
This can be fixed temporarily with an IIS Reset.  But has occured several times over the last month.
Actually there are two symptoms seen on this newer 7.0 installation.
1.  Windows Logoin requests credentials
2.  Enter the web client URL, and get a blank screen, no dialog at all.
Publicado Mon, 25 Mar 2019 17:44:29 GMT por Casey Miller Director of Technical Services
This is the same bug that happened in 6.10 or 6.11. It was eventually fixed with a hot fix. Sounds like they are getting the same issues with version 7. I haven't run into the blank screen issue yet, but have had the windows pop up issue quite a bit.. Hopefully they fix this..
