Publicado Fri, 20 Dec 2024 08:33:45 GMT por Ioritz Escudero
I am having problems with MySQL Administrator 8.0.28 backups.
We have docuware version 7.8 with Internal Database V3.
The error is generated when we perform the backup in the docuware tables and the message is as follows:
"An error ocurred while executing the backup"
This error causes the database service to stop every time the backup is executed.
Do you know if there is any limitation or problem between these versions?
I would appreciate a help
Thanks in advance
Publicado Sat, 28 Dec 2024 00:01:11 GMT por Matthias Wieland Senior Director Support EMEA
Dear Ioritz Escudero! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-250288-T0T1H for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
