Publicado Mon, 20 Aug 2018 19:43:05 GMT por Vinny Johnson All Document Solutions Consultant
I am wanting to move a few file cabinets from one data connection to another in 6.12.  I've created the new data connection, copied the appropriate tables, but I don't see where can I change the data connection?
Publicado Tue, 21 Aug 2018 11:22:53 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Vinny,
It is not so straighforward to change the database with 6.12 and up now. The data connection setting is in Configurations > File Cabinet > More options, but it cannot be changed after the file cabinet is created.
You will need to edit the File Cabinet Settings directly to change the connection name and GUID. Make sure to backup DWSYSTEM before doing that. After the change all services must be restarted along with an IISReset.
Also, did you copy over the DWSYS table? That must exist in the new database too.
Publicado Tue, 21 Aug 2018 12:40:26 GMT por Vinny Johnson All Document Solutions Consultant
Thx Phil...I'll give it a shot
Publicado Tue, 21 Aug 2018 12:49:44 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Aim carefully. :)
