Publicado Tue, 04 Feb 2020 13:31:03 GMT por Dean Birks ABC Digital Solutions LTD Professional services
I have a customer on 6.7 and has only just started to use the Web Client.
They have baskets set up that files from workflows go into and also scanned docs. When i try and find these baskets in the document tray locations they are there and i cant select them. I know that windows client and web client are set up in two different programmes but how do i get them to look at the same baskets/trays?
Dean
Publicado Tue, 04 Feb 2020 13:32:04 GMT por Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Dean Birks! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-119956-D7Y1F for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
Publicado Tue, 11 Feb 2020 15:59:38 GMT por Matthew Trembly Software Support Manager
Dean,
What exactly are you trying to do?  DocuWare Web Baskets/Document Trays are not compatible with the fat client baskets.
Publicado Fri, 14 Feb 2020 11:39:16 GMT por Dean Birks ABC Digital Solutions LTD Professional services
Thanks for getting back to me.
The user has baskets set up that they can see in the FAT client but they want to start using the web client trays.
Is there a way of getting the documents that show in the baskets on the FAT client to show in the web client?
Dean
Publicado Fri, 14 Feb 2020 16:38:52 GMT por Matthew Trembly Software Support Manager
Hello Dean,
Thank you for the clarification.  The two baskets are not compatible.  You can migrate the FAT client basket docs to trays, and then I suggest to just scan new docs to trays with DW Scanner or DW Import.
