Publicado Fri, 31 May 2019 14:15:17 GMT por Casey Miller Director of Technical Services
Running DocuWare version 7 and when users do a multi cabinet search, it doesn't let them edit index entries. Is this by design? If they want to edit, they then have to go to the direct search dialog for that cabinet and edit the index entries.
Publicado Thu, 06 Jun 2019 19:07:40 GMT por Craig Heintz SE
Generally multi-cabinet searches use one cabinets search and result dialog associated with it.  Having common fields between cabinets makes it bring results form different cabinets.  Editing index data does not work because the dialogs are for a different cabinet.
You may be able to open the document and choose edit index from the viewer icons and see if that will work for you.
