Publicado Wed, 06 Mar 2024 09:46:59 GMT por Jan Picht Vision Office Technical Services PLC Senior Technical Consultant
I have a table field with line items of delivery notes. Somehow I need to be able to remove lines from the table field where the "Quantity" (one of the columns, decimal, 4 decimal digits) contains "0.0000"
The table field looks somewhat like this at the beginning:
Sys Line No
Quote Line No
Product Code
Quantity
1
3
Prod123
12.0000
2
2
Prod234
0.0000
3
1
Prod345
10.0000
After removing the unwanted line I would expect this:
Sys Line No
Quote Line No
Product Code
Quantity
1
3
Prod123
12.0000
2
1
Prod345
10.0000
Any help is greatly appreciated!
Thanks!
Jan
Publicado Wed, 06 Mar 2024 15:18:33 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Jan Picht,
as far as I know, this is currently (DW 7.9) only possible via user interaction or by overwriting the table via REST API.
Publicado Wed, 06 Mar 2024 16:09:53 GMT por Jan Picht Vision Office Technical Services PLC Senior Technical Consultant
Hello Simon,
Thanks for the info! However, is there not a way to transfer the table lines to another table field and apply a filter or match code (Quantity >=0.0001) to the transfer in a Data Assignment step?
Any "outside of the box" solution would be great, too... I am thinking about using Autoindex to transfer the table lines to a temp. cabinet and then import them from there into a separate table field omitting the unwanted lines... But that would mean a lot of configuration and potential timing issues if Autoindex is not triggered quickly enough, etc...
Thanks again for any ideas!
Jan
Publicado Wed, 18 Jun 2025 13:53:30 GMT por Serhan Polat Gerard Bürokommunikations GmbH DMS Consultant
does anyone have a solution for this?
I'm trying to fill an empty table with variable data without user interaction. Since that doesn't seem to be possible, I considered retrieving a pre-filled table from another document and deleting the unnecessary rows — but I haven't found a working solution for that either.
It's frustrating how such a simple task can't be set up in a straightforward way.
Regards,
Serhan Polat
Publicado Mon, 23 Jun 2025 09:11:40 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Serhan Polat,
as far as I know, this has not changed between 7.9 and 7.12.
You still need user interaction OR an application which does these operations using the REST/.NET API.
