Publicado Thu, 09 Sep 2021 17:08:45 GMT por Steve Shriver Application Specialist
An AutoIndex job is configured to update a field in a File Cabinet (Cabinet A) based on a match in the source, also a file cabinet (Cabinet B). The source is the shorter list so it is the first read. Both file cabinets have numerous records and the job takes a long time to complete.
To shorten the time the configuration is filtering the source, Cabinet B, on a field value. There are multiple matches in Cabinet A for each record in Cabinet B. The write back updates the same field in Cabinet B that is used for the filter to prepare for the next run.
Can I assume that the write back will occur after all of the matches in Cabinet A are found and updated? If the write back occurs after the first match is found, would that filter out the record in the source Cabinet so that the remaining matches would be skipped?
Publicado Fri, 10 Sep 2021 14:34:38 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Steve,
to my understanding, the writeback for one entry happens after every found entry was processed.
However, I have not tested this and am not 100% sure.
Publicado Fri, 10 Sep 2021 19:28:17 GMT por Steve Shriver Application Specialist
Simon, Thanks for your reply.
Do you think I am correct to be concerned? There will be multiple entries in Cabinet A for each found in Cabinet B, that need to be updated. I want to make sure that I get them all. If the write back occurs after the first match is found, will that filter out the source entry from making further matches?
Publicado Sat, 11 Sep 2021 16:09:42 GMT por Steve Shriver Application Specialist
Update FYI...
I tested the configuration where the write back updates the field being filtered on. It does update the multiple entries in the original file cabinet properly as well as the field in the source file cabinet
Thanks again,
