Publicado Thu, 07 Feb 2019 06:09:50 GMT por Kjetil Kulterud Service Owner
Is it possible to remove spaces between characters in a field?
When using One Click Indexing a number is stored like this 111 222 333.
When searching the customer want to search on the whole number without spaces, ie111222333.
Publicado Wed, 12 Feb 2020 11:34:15 GMT por Dean Birks ABC Digital Solutions LTD Professional services
did anyone ever find a solution to this. I have a similare issue with serial numbers. It adds spaces after a number or letter.
eg . A5C21343455 when autoindexed comes out as A 5 C 21343455
Any ideas?
Dean
Publicado Wed, 12 Feb 2020 12:20:14 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Dean,
you can do this with a data assignment in a Workflow using the "replace" function in an arithmetic expression:
Replace(String, String, String, Int32, Int32, CompareMethod)
//Returns a string in which a specified substring has been replaced with another substring a specified number of times.
example: Replace(GV_Number," ","") would replace all spaces in the global variable "Number" with nothing.
