Publicado Thu, 16 Nov 2023 20:02:16 GMT por Michael Weingand Professional Services Manager
HI Folks,
My customer has asked if it;s possible to add a second field in a stamp that pulls from a multi column select list.  Example.  They have a field called GL code that is being pulled from a select list connected to a database. They would also like the GL name, but I don't have a way to select in configuration what column it is puling from.  It looks like it will only pull from the first column.  Can anyone figure out a way to do that.  Also if that is possible, can the two be linked, so when you select the GLcode, the second field only has the GL code associated with the first column.
Thanks for any input you might have.
Publicado Fri, 24 Nov 2023 00:00:19 GMT por Matthias Wieland Senior Director Support EMEA
Dear Michael Weingand! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-217111-R4B3J for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
