Publicado Mon, 17 Mar 2025 16:38:26 GMT por Scott Roberts Xerox Senior Technology Consultant
Has anyone done any integrations with Acumatica?
Publicado Tue, 18 Mar 2025 07:03:37 GMT por Edward Sant Fournier Senior Software Applications Analyst
I'm also interested in this request - integration with Acumatica
Publicado Mon, 05 May 2025 18:51:56 GMT por Jeff Slack ECM Specialist
I'm also interested to know what this integration would look like.
Publicado Fri, 09 May 2025 08:02:23 GMT por Gerardo Lisanti Team Leader Product Management
Hi Scott, Edward, Jeff,
I believe you can integrate with Acumatica's REST API using the Workflow Web Service activity in DocuWare. Based on my research, Acumatica provides OpenAPI 3.0 (Swagger) definitions, which can be imported into the DocuWare Workflow Designer to simplify integration. Additionally, Acumatica offers a range of REST API Examples that demonstrate various operations. For instance, to retrieve a list of accounts you can use the following GET request:
GET https://<your-acumatica-instance.com>/entity/Default/24.200.001/Account?$filter=AccountGroup%20eq%20'ACCG02'&$select=AccountCD
Authorization should be possible using OAuth2 Token via DocuWare Web Service configurations, see Authorization Code Flow: Obtaining of an Access Token and ID Token
I hope this helps!
Team Leader Product Management  |  DocuWare GmbH
