Publicado Mon, 14 Jan 2019 18:34:34 GMT por Josef Zayats
Original message removed - as it was incorrect and misleading.
See Phil's reply.
Publicado Mon, 14 Jan 2019 18:44:41 GMT por Phil Robson DocuWare Corporation Senior Director Client Services, Americas
Josef.
Select your source cabinet, then in the match code section select "File Cabinet Database". Select the same file cabinet. You can then match on "Doc Id" equals "Doc Id".
Publicado Mon, 14 Jan 2019 18:57:00 GMT por Josef Zayats
Phil,
thank you for pointing this out to me. I got confused by the new name being Doc ID instead of DWDOCID.
DUH!
Publicado Mon, 14 Jan 2019 19:00:53 GMT por Phil Robson DocuWare Corporation Senior Director Client Services, Americas
That happened to me too. By the way, the "File cabinet database" option is a lot faster than the old external database method.
