Publicado Mon, 29 Jan 2018 08:46:11 GMT por Kjetil Kulterud Service Owner
Is it somehow possible to automatically delete, or put documents in a list that have the exact same content?
Publicado Mon, 29 Jan 2018 12:31:27 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
There is no automatic function in DocuWare to detect documents that have the same index information. Even with the same index information it is not neccessarily going to be true the the documents themseleves are identical. This will need to be a manual task carried out by a user.
Publicado Mon, 29 Jan 2018 12:59:56 GMT por Kjetil Kulterud Service Owner
Publicado Mon, 29 Jan 2018 15:41:24 GMT por Casey Miller Director of Technical Services
see this forum a while back. If you are using on premise, you can use this sql syntax and create a LIST that will show the dupllicate document. https://www.docuware.com/forum/english-forums/docuware-questions-about-u...
