Publicado Thu, 31 Oct 2024 22:44:59 GMT por Michael Weingand Professional Services Manager
HI Folks,
Is there a way to move Documents to another Cabinet in workflow.  My customer has about 15K files out of 45K in one cabinet that need to be moved to another. They can move them manually but only 100 at a time after a search.
Publicado Fri, 08 Nov 2024 00:00:21 GMT por Matthias Wieland Senior Director Support EMEA
Dear Michael Weingand! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-245401-Q0C8F for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Publicado Fri, 15 Nov 2024 11:51:56 GMT por Jan Kanters Digital Transformation Enabler
Michael
did you consider using a workflow to be triggered by an autoindex.
In the workflow you can use the endpoint transfer /FileCabinets/Task/Transfer
Publicado Fri, 15 Nov 2024 16:11:01 GMT por Michael Weingand Professional Services Manager
Transfer worked without needing the workflow.
