Registrato Thu, 07 Jan 2021 15:03:16 GMT di Kenny McDannald KENCO Engineering Design Engineer
Several users are experiencing showing one column in doc trays and view lists.  The documents over shadow each other and can't figure out which document is which.  Does not appear to be browser specific.
Registrato Thu, 14 Jan 2021 15:03:16 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Kenny McDannald! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-141978-N7Q6J for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Registrato Mon, 25 Jan 2021 16:02:09 GMT di Neal Ford Information Service Manager
We recently upgrade to DW 7.1 and some users are experiencing the same issue.
Has there been a solution made for this?
Neal
Registrato Mon, 25 Jan 2021 16:05:57 GMT di Martin Zebedies Uriot GmbH & Co. KG Head of Solution Consulting
Have you tried to move the bar from the right side to the middle?
it looks like the viewer basketview is max width?
Registrato Mon, 25 Jan 2021 16:35:06 GMT di Kenny McDannald KENCO Engineering Design Engineer
A support person from DocuWare logged in remotely and did an iisreset on the server, then he restarted all of the DocuWare services, which fixed our problem.  i hope it is that easy for you.
Registrato Mon, 25 Jan 2021 16:55:09 GMT di Neal Ford Information Service Manager
Did they just "restart" the IIS or actually did a reset because we have a redirect in place. It's weird it only seems to be affecting some people and not others but noticing more and more.
Registrato Mon, 25 Jan 2021 17:29:55 GMT di Neal Ford Information Service Manager
**Fixed It**
Restart the IIS services appeared to resolve the issue.
I will be perform a full restart of all the services tonight to ensure things are working properly.
Cheers,
Neal
