Registrato Wed, 21 Nov 2018 18:34:54 GMT di Casey Miller Director of Technical Services
We are on DocuWare  intermittentley workflows will not start. After restarting the workflow server and background services all the documents entered that workflow hasn't started on start the workflows. Has anyone run into this? Is there a hotfix for this?
Registrato Wed, 21 Nov 2018 18:53:07 GMT di Shawn Rutigliano software support analyst
Hello Casey,
It sounds like even though the services have been started, the workflows are still not getting triggered? Please submit a support request so we can better assist you with this. Thank you
Best Regards
Shawn Rutigliano
Software Support Analyst
Team RED Americas
Registrato Wed, 21 Nov 2018 19:40:00 GMT di Casey Miller Director of Technical Services
it is weird. I can go to the documents that I know the workflows should have started for and look at WF History and it says no workflows have been started. Then after I restart the services all of the documents that should have triggered the workflow now trigger and start. I will create a service request.
Registrato Thu, 22 Nov 2018 13:14:56 GMT di
Hey Casey,
try to reset msmq, maybe it´s the solution for you
Registrato Thu, 22 Nov 2018 15:41:47 GMT di Gilles Sauvagnat Altexence
Hi Casey,
Are you on DW V7 ? If yes, install the latest hotfix. Then unpublish and re publish your workflows
Sounds like black magic. Although it worked for me and was suggested by DW support
Gilles
Registrato Wed, 28 Nov 2018 20:57:58 GMT di Casey Miller Director of Technical Services
restarting the Background and workflow server services fixes issue so that is the workaround for now.
Registrato Wed, 28 Nov 2018 21:09:24 GMT di Casey Miller Director of Technical Services
I will put it a server change request and give this a try. Thanks.
