A customer of ours have several document they want to delete 12 months after the "end date" is set in one of the metadata fields.
How could I solve this with the Deletion Policy module?
Thanks!
With DocuWare 6.12:
End Date Is Before the Past 12 Months
Phil RobsonSenior Director Support Americas
https://www.docuware.com/sites/default/files/forums-images/DeletionP.png
I created a new Deletion Policy, but when i execute the proccess, give me back the next message: "Server is not responding"
https://www.docuware.com/sites/default/files/forums-images/deletion%20policy.png
Hello Salvador,
have you tried restarting the DocuWare WorkflowEngine and BackgroundProcess Processes?
Hi Kjetil Kulterud, i re started before the process you asked me, and it doesn´t make difference.
Thanks.
Hello Phil,
I want to delete all of the documents older than 2 months old based on the date of the report (metadata) and not the date of document storage. Field is called Date. Would I then do "Date Before the Past 2 Months"? Just want to be sure I understand the logic in the statement.
Thank you,
-Dylan
Dylan,Yes to delete all documents older than 2 months would be "Before past 2 months". You can use any Date type field in your file cabinet to test against.
Ottieni aiuto
