Registrato Thu, 29 Mar 2018 16:13:13 GMT di Keith Telford App. Support
We are going to be scanning checks into docuware and would like a watermark on the check so they can not be printed and reused
Is a watermark possible and how this be done.
thanks
Registrato Thu, 29 Mar 2018 16:22:46 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
DocuWare WebScan creates a PDF of the document - basically an image encapsulated in a PDF. There is no function in DocuWare to add a watermark. What is possible, is that after the document is delivered to a web tray, a stamp can be applied and merged with the document so that it is a permanent part of the document and cannot be removed. Unfortunately, this is a manual process and cannot be automated. Automation of this can be developed with the Platform SDK by a programmer.
Registrato Thu, 29 Mar 2018 16:40:56 GMT di Keith Telford App. Support
ok thanks i will talk to the business about this as a possible solution ...have a happy easter
Registrato Thu, 29 Mar 2018 16:54:00 GMT di Josef Zayats
Keith,
you could add a predefined image to your checks by configuring Form/Letterhead tab to an import configuration to be used with Docuware scanner, or if you use a different way to scan, such as scan to a folder, the import configuration to be used with an Import Job.
The image from letterhead could be made 'transparent' - this would be pretty much close to a watermark
Registrato Thu, 29 Mar 2018 16:55:52 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Josef,
Perfect. I did not even consider that. Nicely automated too.
Registrato Wed, 04 Apr 2018 11:43:48 GMT di Keith Telford App. Support
Would these two options be considered annotations ...if so the users would have the abiltiy to print without annotations ..please advise thanks again
https://www.docuware.com/sites/default/files/forums-images/DWannt.JPG
Registrato Wed, 04 Apr 2018 14:07:00 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Josefs method will create a new document with the overlay an indelible part of the document.
My methos IS an annotation but you must MERGE the annotation with the document to make it also an indelible part of the document. If you do not merge then yes, it would be able to be printed without the annotation.
Josef's method is fully automated and is not subject to someone forgetting to merge the annotation.
