Registrato Wed, 09 Feb 2022 04:44:54 GMT di Tiago Matos CoreForm Business Technology - Software Implementation Specialist
A prospect is asking if Docuware provides:
  1. Copies of recent penetration test reports
  2. Lock access down to corporate IP addresses
  3. Single-Sign-On support
  4. Multi-factor authentication supported
Does anyone know the answers?
Tiago
Registrato Thu, 10 Feb 2022 08:26:52 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Tiago,&nbsp;<br> <br> as far as I know (for Europe)<br> <br> 1. most likely not<br> 2. definitely not, had that request from one of my customers as well<br> 3. yes, Azure AD<br> 4. currently not, but I think it is a planned feature, you might want to check uservoice.<br> <br> Greetings from Germany,&nbsp;<br> Simon H. Hellmann<br> DocuWare System Consultant
Registrato Thu, 10 Feb 2022 15:32:16 GMT di Craig Heintz SE
Multi-Factor is supported thru <strong>Azure AD</strong> or <strong>ADFS</strong>&nbsp;and is set up in those external authentication methods.&nbsp; DW simply relies on them to allow a user before it allows a user to login.
Registrato Thu, 10 Feb 2022 21:59:14 GMT di Tiago Matos CoreForm Business Technology - Software Implementation Specialist
Thanks Simon and Craig.<br> &nbsp; <grammarly-desktop-integration data-grammarly-shadow-root="true"></grammarly-desktop-integration>
Registrato Fri, 11 Feb 2022 14:35:27 GMT di Christopher Nicoli Project Manager-Sr Systems Engineer
in regards to item#1 - you may be able to request the SOC2 report that shows their testing -  item#2 locking down access by corporate IP address - we have accomplished this using the Azure AD SSO integration and only allowing access by the corporate public IPs. item#3 - can be done via azure ad sso. also #4 MFA was accomplished using azure ad sso integration as well
Registrato Sun, 13 Feb 2022 21:45:16 GMT di Tiago Matos CoreForm Business Technology - Software Implementation Specialist
Thanks Christopher
