投稿済み Wed, 05 May 2021 15:24:22 GMT 、投稿者 Steve Shriver Application Specialist
A user of a cloud system has several email notifications configured. He notices that these notifications fail to trigger after a cloud Desktop Apps update is pushed out. Once the end user's PC has been updated the notifications resume as designed.
This is a problem as the security at this organization prohibits end users from installing the update and the IT staff must respond to each instance.
Has anyone else seen this happen? Any workarounds available?
投稿済み Wed, 05 May 2021 17:22:42 GMT 、投稿者 Craig Heintz SE
Yes, updates to Desktop Apps can cause a variety of issues for end users when their PC is out of sync with the Cloud version of Desktop Apps.
My solution has always been to run the silent installer -update as a local admin.  Generally IT can set up a method to make this happen on a users workstation.
This can be run as often as needed.  If an update exists then it gets done.  If there is no update nothing changes.
Here is the KBA associated.
https://support.docuware.com/en-us/knowledgebase/article/KBA-36355
投稿済み Thu, 06 May 2021 06:44:00 GMT 、投稿者 Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Steve,
personally I do not think, that a missing Desktop Apps update should stop triggering email notifications as these two topics are not connected to each other. I think you should contact our support to investigate this further.
Tobi
