投稿済み Wed, 22 Sep 2021 19:43:55 GMT 、投稿者 Angel Hernandez
In the Replace Text section there's an "Old value" and a "New value" field where you can add the values manually. There's also a button to import the values from a file but I can't figure out how to import both the Old value and the New value. I tried importing a CSV file with Old value in column A and New value in column B but when it imports it imports both columns into the Old value section (see attached screenshot in attached document).
How can I import a list of Old values and New values?
投稿済み Thu, 23 Sep 2021 13:31:28 GMT 、投稿者 Craig Heintz SE
This will work for you.
Use a semicolon between column data.  This is probably so a comma can be used in a data value.
Works:
Canada;Moose
Pinto;Horse
Not Working
Canada,Moose
Pinto,Horse
投稿済み Thu, 23 Sep 2021 16:19:57 GMT 、投稿者 Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Angel, Hi Craig,
this is most likely due to the fact that CSV files in Germany are not separated by a comma, but by semicolon - its just a different standard in Germany than in the US.
The German developers probably didn't think this through and implemented it only with semicolon CSV files.
投稿済み Thu, 23 Sep 2021 16:50:57 GMT 、投稿者 Jon Weston File IT Solutions Sr Application Developer and RIM specialist
I'm firmly on the side of the developers with this one.  CSV files are a nightmare because commas show up way to often in live data so I never use commas as delimiters if there's any other option - I usually use a vertical bar but I've had clients that will opt for the ^
Having said that, it would have been good to know that they were using semi-colons.
