投稿済み Mon, 19 Feb 2018 18:22:12 GMT 、投稿者 Joe Heaton VP
I want to be able to run DocuWare desktop apps to run as a service to pull files in from a shared folder.  Is this possible?
投稿済み Mon, 19 Feb 2018 18:31:40 GMT 、投稿者 Joe Kaufman Bell Laboratories Inc No longer there
Joe,
DocuWare Desktop is pretty much already a service, and you can set up what is called an "import job" to pull in documents from a watched folder.
Install all the DocuWare Desktop tools and you should have an "Import" tab in the DocuWare desktop apps. Read the help on it and set up a job and you should be ready to go.
投稿済み Mon, 19 Feb 2018 18:34:03 GMT 、投稿者 Joe Heaton VP
Agreed, what I am looking to do is have the import jobs running whether the user is logged in or not.
投稿済み Mon, 19 Feb 2018 18:40:49 GMT 、投稿者 Steve Shriver Application Specialist
Yes it is, so long as the folder being monitored is considered 'local', that is, accesible to the user running the desktop service on that machine.
投稿済み Mon, 19 Feb 2018 18:42:53 GMT 、投稿者 Jon Weston File IT Solutions Sr Application Developer and RIM specialist
Yup, that's how it works Joe - the user doesn't have to be logged-in.  I had a glitch with a client this week where the jobs would occasionally stop (once per week) until the user logged in and DW support told me to set the Desktop Service to "Automatic (delayed start)" to avoid that problem.  I've also encountered problems when the monitored folder is a network folder so I try to have the monitored folder be local on the machine that is running the import jobs as much as possible.
投稿済み Mon, 19 Feb 2018 18:47:42 GMT 、投稿者 Joe Heaton VP
Thanks I had a service account created by my IT department and will try using that to start the service.  That account also has access to the shared folder although it is a network share.  I will try it out.  Appreciate the responses.
