Veröffentlicht Fri, 04 Feb 2022 20:30:31 GMT von Jon Weston File IT Solutions Sr Application Developer and RIM specialist
I recall at DocuWorld last year they said that we could create our own preconfigured solutions by exporting a system to a dwbuc file.  I'm just starting a new cloud project and it occurred to me that this would be a good preconfigured solution (for various reasons) but when I tried to export my solution it says "Export is only supported for DocuWare systems that have been specifically set up as source system for a preconfigured solution. Do not export production installations as this will fail."
Am I remembering wrong and we can't create our own?
Veröffentlicht Sun, 06 Feb 2022 13:43:28 GMT von Marcin Kratiuk
Using this tool you can create the copy of the configuration. https://youtu.be/8Oz1N-h-q9c
Veröffentlicht Mon, 07 Feb 2022 09:47:48 GMT von Gerardo Lisanti Team Leader Product Management
Hi Jon,<br> <br> yes, that's right you can create your own preconfigured solutions.<br> The message you are referring to is a cautionary message indicating that there are certain limitations.<br> So it is not meant to simply "clone" a system.<br> <br> Please find more information in the manual, here:&nbsp;<a href="https://go.docuware.com/preconfigured-solutions-manual" target="_blank">https://go.docuware.com/preconfigured-solutions-manual</a><br> <br> Viele Grüße / With best regards,<br> <br> --<br> <br> Gerardo Lisanti<br> Manager Product
