New 6.12 install with lateset hotpack. Not many document in Cabinet.  Only 10 or so testing.
Import process created to import files from folder structure.  Copying 1 Folder and 7 Subfolders to an import folder.  Indexing is only based on the Parent folder mapped to text field named Case Name, and subfolders mapped to text field named Document type.
68 files in 8 folders only 43 megs.  Taking 25-30 minutes.
 Dual Core 2.1 with 8 gigs ram. CPU at 99% ram at 60%.
Any advice on what could be causing this.
Thanks for any help on this one.
