Publicado Thu, 11 Jun 2020 00:43:33 GMT por David Blake Ricoh USA Sr. Solution Integrator
It has been noted with Workflow Queues only one column can be pre-sorted.  Result Dialogs can be pre-sorted over three columns.  Is this correct, and should we submit a feature request for this disparity?
Publicado Thu, 11 Jun 2020 07:07:05 GMT por David Barlet Technical Manager
Hello David,
With 'Shift' key you can select several column to sort workflow task..
Best regards,
David
Publicado Mon, 15 Jun 2020 11:39:43 GMT por Tobias Getz DocuWare GmbH Team Leader Product Management
Hi David (1),
by pre-sorted you probably mean the sorting setting in the Designer. You are correct that this is only available for (result) lists and not for workflow tasks. You can submit a feature request through the Customer Feedback Forum.
Director Product
