Registrato Mon, 10 Jun 2019 12:36:50 GMT di Steve Shriver Application Specialist
Does anyone have any experience with or suggestions on how to do (or if it's possible) Digital Signatures within a DocuWare workflow on a DW Cloud system?
Registrato Mon, 10 Jun 2019 13:29:31 GMT di Casey Miller Director of Technical Services
Have been trying to figure this out for a long time. I don't think there is a way right now. I am following too!
Registrato Mon, 10 Jun 2019 16:10:48 GMT di Gilles Sauvagnat Altexence
Hello
Depends what kind of signature you want but whatever your choice you will need some piece of code as a webservice
We do that either with an external platform such as Universign or by using a certificate stored locally
Gilles
Registrato Mon, 10 Jun 2019 18:24:19 GMT di Steve Shriver Application Specialist
Gilles,
How would a locally stored certificate work with access
from almost anywhere to a DW Cloud system?
Does everyone need a certificate on each PC?
Phone or tablet access?
Registrato Wed, 12 Jun 2019 05:17:35 GMT di Gilles Sauvagnat Altexence
Steve,
Depends what kind of digital signature you want and from which devices
If you want to use phone, tablets, PC and legal proof signature you need an external services from a certified authority such as Universign (that's the service we mainly use)
Gilles
Registrato Wed, 12 Jun 2019 13:10:12 GMT di Steve Shriver Application Specialist
Thanks Gilles. Did you integrate using the DW API, or is there an easier way?
Thanks again,
Registrato Wed, 12 Jun 2019 15:36:39 GMT di Gilles Sauvagnat Altexence
Hi Steve
I do not know an easier way as DW SDK/API.
So yes, we did the integration using both DW API and Univesign API, to get a fully integrated solution.
Gilles
Registrato Sat, 26 Oct 2019 18:40:12 GMT di Pedro E. Gonzalez-Santini Gm
DocuWare 7.2 offers integration in a workflow using Validated ID, a cloud digital signature service. We have discussed this but not yet tested it.
