投稿済み Fri, 27 Sep 2019 19:51:29 GMT 、投稿者 Steve Shriver Application Specialist
Would it be possible to use the XML file created by the system backup option in the admin tool, to restore a system to another installation of the same version of DocuWare, with the same license file, on a different machine? For instance as a way to move a test environment to production.
投稿済み Fri, 27 Sep 2019 19:55:33 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Yes. The backup is designed to recover the DocuWare system in the event of catastrophic failure. Remember that the target system must be empty - that is just a basic install. You cannot replace a running system.
投稿済み Fri, 27 Sep 2019 20:12:14 GMT 、投稿者 Steve Shriver Application Specialist
Thanks Phil, I thought that was the case. But now I can't find a way to run the restore. Has that be removed from the admin tool?
Thanks again,
投稿済み Fri, 27 Sep 2019 20:16:06 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
You know I have not run that thing since oh, about 1962. Get Support to check on that for you.
Phil.
投稿済み Fri, 27 Sep 2019 20:40:59 GMT 、投稿者 Steve Shriver Application Specialist
Found it. In the admin tool on the tools menu. There is an item for creating a backup as well as restoring from one.
投稿済み Fri, 27 Sep 2019 20:42:50 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Goodo!
Phil.
投稿済み Thu, 07 May 2020 14:24:01 GMT 、投稿者 Kim Sims Technical Solution Architect
Phil,
I've been attempting to perform a test restore to determine if it will perform as expected in a DR environment, but, I continually receive errors as seen in the attached image.
Initially I assumed it was due to different credentials for the db, so, since this is a test environment, I uninstalled and reinstalled using the same windows admin acct as well as the db acct, but, still receive the same errors.
I'd like to explore the built in functionality of the the back up and restore process for future reference.
投稿済み Fri, 29 May 2020 17:56:48 GMT 、投稿者 Kim Sims Technical Solution Architect
Anything new?
投稿済み Wed, 03 Jun 2020 13:44:55 GMT 、投稿者 Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Kim,
I think this should be handled with a support request. Please create one.
Director Product
