Veröffentlicht Mon, 17 May 2021 14:13:43 GMT von Steve Shriver Application Specialist
Does a user assigned a Workflow license have the ability to Clip a document to another document within a workflow task?
Can a user assigned to a Workflow License fill out and store a Form that then triggers a workflow?
Veröffentlicht Tue, 18 May 2021 14:26:47 GMT von Craig Heintz SE
here is what I have regarding your Q.
Veröffentlicht Tue, 18 May 2021 16:31:13 GMT von Jon Neff Kelley Imaging Solutions Engineer
Which of the Desktop Apps function and to what degree under the Workflow License?
Veröffentlicht Wed, 19 May 2021 07:25:06 GMT von Tobias Getz DocuWare GmbH Team Leader Product Management
The user which has a Workflow user license assigned can fill out a form and submit it. The Workflow process is a separated process so yes, this will work.
As a user assigned to a workflow license no functionality works, that will store or edit a document in DocuWare, only searching is available. Do you have any specific functionality you would like to use?
