Publicado Tue, 10 Jul 2018 12:15:16 GMT por Dane Summers Solutions Support
Good day.
We would like to use REST API services for integration, but always get the "401 Unathorised" error message.
Any advise on how to validate a user using the REST URI /DocuWare/Platform/Organizations/{id}/ValidateUser
The documentation is not clear.
Assuming the following details, kindly provide an example of how one goes about validating the user.
Server NameUser NamePassword
Details
docuware admin password
Dane
Publicado Tue, 10 Jul 2018 12:34:08 GMT por Joe Kaufman Bell Laboratories Inc No longer there
Dave,
You don't need to use the ValidateUser resource (that I know of), you just need to POST the username and password, and then your connection object will remain connected until logging off or timing out.
See these links:
https://www.docuware.com/forum/english-forums/docuware-help-technical-problems/using-platform-sdk-other-dev-tools
https://www.docuware.com/forum/english-forums/docuware-questions-about-usage-and-configuration/using-api-rest-function-deal-document-actions
I believe you can also place username and password in the header of your requests and authenticate each time, but I cannot find the thread on that at the moment... Oh, wait, this is it:
https://www.docuware.com/forum/english-forums/docuware-help-technical-problems/platform-sdk-urls-and-serverxmlhttp-object
Those links should get you where you want to be with regard to using the Platform API from tools not part of the .NET environment.
Publicado Tue, 10 Jul 2018 13:07:00 GMT por Dane Summers Solutions Support
I will review your links and revert if anything is unclear
Appreciated.
Publicado Tue, 10 Jul 2018 14:48:00 GMT por Joe Kaufman Bell Laboratories Inc No longer there
Dane,
I do HTTP request testing with Postman, it works pretty well. I have had it work against DocuWare both with the POST data authentication and the header-based authentication.
You can download Postman here:
https://www.getpostman.com/
Good luck!
Publicado Fri, 06 Sep 2019 08:14:34 GMT por Marc Stauffer Senior Consultant
It sucks a little that these links don't work any more:
Would you mind fixing this, if possible? It would help a lot (probably)(I hope), since I am having the same issue and do not want to open a new thread.
Thank you so much
Marc
