Publicado Thu, 22 Feb 2018 16:43:55 GMT por Oleg Karpun Engineer
Hi
I wonder if anyone can help me with following request.
Task approvers need to see only certain fields in Edit Index Entries (Index) dialog in Workflow Manager, while Manager need to see all fields.
Is it possible ?
Publicado Thu, 22 Feb 2018 17:15:08 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Index dialogs are specified along with a Result List. DocuWare normally observes permissions based on these dialogs. Therefore you will need to create a Result list and associated Index dialog with the required fields for your Task Approvers. Ensure that your Task approvers are not associated with a Result list that allows them to see all index entires in the Index dialog.
Publicado Wed, 28 Feb 2018 17:20:22 GMT por Oleg Karpun Engineer
Hi Phil
Thank you for help.
It still asks for default result list. See attached. I created demouser and assigned it to Approvers Search and Approvers Result dialogs.
I wonder what I'm doing wrong ?
Thank you in advance
https://www.docuware.com/sites/default/files/forums-images/iii-2.png
https://www.docuware.com/sites/default/files/forums-images/iii-1.png
Publicado Wed, 28 Feb 2018 17:28:20 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Oleg,
It would appear then that I am wrong. WFM obviously will only use the default result list for the file cabinet. I'm sorry but I do not have a solution.
Publicado Thu, 22 Jun 2023 17:18:43 GMT por Saleem Anwar Senior Programmer Analyst
This question was asked five years ago, and I am currently dealing with a similar issue.&#160; Is DocuWare still lacking that flexibility to use a different result list than the default one for the file cabinet for editing WF tasks?<br> Thanks
Publicado Fri, 23 Jun 2023 10:50:39 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Saleem,<br> <br> starting with (I think) Version 7.5 of DocuWare, you can select which result list a workflow uses, doesn't have to be the default anymore.<br> The setting is located in the &quot;Task List&quot; menu inside of the workflow.<br> A different result list for different tasks within the same workflow is still not possible.<br> <br> Hope this helps.<br> <br> Greetings from Germany,<br> Simon H. Hellmann<br> DocuWare System Consultant<br> &#160;
