Publicado Thu, 02 Jan 2020 11:24:46 GMT por Michael Peeters Service Desk Engineer
Dear,
Example:
One manager, 5 employees
Manager sends a policy change document that the 5 employees need to read. Each of them get a task to read the document.
After one clicks on Confirm, the task should still be open for the other 4 employees.
To do this the manager should send the same document 5 times, each time addressing it (in the store dialog) to someone else.
Is there a way so this does not need to happen? That, when the document is sent to 'public' for example, that everyone gets a task for himself (with a different workflow instance id) that doesn't influence the other tasks of the same document.
Publicado Mon, 06 Jan 2020 08:31:30 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Michael,
for this scenario, you could use a workflow with a parallel task. A parallel task only finishes when every user it is assigned to completes the task - or if a special condition is met. This way, the manager only needs to store one document which starts a workflow - which sends 5 instances of one task to the users.
Publicado Mon, 06 Jan 2020 09:19:06 GMT por Michael Peeters Service Desk Engineer
Hello Simon,
We already tried this, and that works. except for the fact that people lock each other out of confirming.
Let's say you send this to two people that'd be fine, in some way. But send it to 10, 20 or 50 people?
One person could open it and the other 49 would be locked out.
Greetings from Belgium,
Michaël Peeters
Information Capture Consultant
Publicado Fri, 31 Jan 2020 16:00:14 GMT por Tobias Getz DocuWare GmbH Team Leader Product Management
Hello Michaël,
I do not understand why the first person should lock out the others. Each user gets a single workflow task and can open the document. The only locking would happen, if the users have to edit the document or make annotations to it. Taking a decision with the workflow should work fine.
Director Product
Publicado Tue, 04 Feb 2020 18:17:59 GMT por Matthew Trembly Software Support Manager
Michael,
Is the lock message something along the lines of:
“Cannot lock document 65944 because it is already locked in another session”
