Hello Tracy,<br>
<br>
which DocuWare Version are you using? <br>
In a recent Version (I think 7.3, but not sure) the system fields (like store date) can be activated in every type of dialog via file cabinet configuration -> dialogs, so your workaround is not needed anymore.<br>
<br>
In older versions, you had to copy the value to another index field like your proposed solution, the easiest workaround for that would be an autoindex job. If autoindex is not licensed, you can also implement this workaround via workflow designer or sql script/database trigger.<br>
<br>
Hope this helps.<br>
<br>
Greetings from Germany,<br>
Simon H. Hellmann<br>
