Publié Mon, 12 Feb 2024 10:04:04 GMT par Mélanie Mélanie
How can we increase the size of uploaded documents in Forms for Docuware 7.9 please ? By default, it is 20MB. I tried this solution but it didn't work : KBA-36849
Thanks a lot,
Best regards
Publié Tue, 13 Feb 2024 16:05:24 GMT par David Barlet Technical Manager
It can be done Forms by form directly in the database (max 400 Mb) :
<Content removed as database manipulations to increase the size are not supported!>
Publié Tue, 13 Feb 2024 16:13:32 GMT par Mélanie Mélanie
I want to do it for all forms, it is not possible? We have to do it for each form individually and not forget to change this parameter every time we create a new form?
Thanks again,
Best regards
Publié Thu, 22 Feb 2024 09:07:24 GMT par Christian Hohenberger Director Support Team PURPLE EMEA
Dear Mélanie, dear David,
please note that I had to remove the recommended solution by adapting the database. This approach is neither generally recommended nor officially supported by DocuWare Support and Development. DocuWare is aware of the need to offer larger sizes for the file attachment fields and working on a solution for the upcoming Version of DocuWare. At the moment, we cannot share definite numbers for the future limit values, but it is planned to be able to increase the current values significantly.
Best regards,
Publié Fri, 23 Feb 2024 16:09:29 GMT par Craig Williams President/ CEO
Good to note, looking forward to the change
