投稿済み Thu, 28 Feb 2019 11:08:16 GMT 、投稿者 Andreas Ruttkamp
I have deinstalled dw 6.12 on an machine and wish to install a fresh dw 7.
But... setup offers only "update" or "deinstall" ... New system isn´t available.
Are there an option to start setup in an "install" mode to install dw 7 anyway ?
投稿済み Thu, 28 Feb 2019 13:19:25 GMT 、投稿者 Casey Miller Director of Technical Services
make sure after the uninstall, that you delete the docuware folders at installation path.
C:\Program Files x86\Docuware
 Also go to %localappdata% and %programdata% and make sure to delete docuware folders in these locations. After this, try running
投稿済み Thu, 28 Feb 2019 17:54:55 GMT 、投稿者 Tim Ohm
Check the windows installer cache for any DocuWare MSIs.  It is a hidden folder, even with 'show hidden folders' enabled, so go there manually - C:\Windows\Installer.  You'll want to add the author and comment columns to find useful files.  It could be something is still stuck ... so right click on the MSIs and choose uninstall.  Not sure if that is the issue, but worth checking.
投稿済み Thu, 28 Feb 2019 18:01:30 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Easiest is to find the Microsoft Installer cleanup tool. I found it a few weeks ago. Run that and remove any DocuWare msi's (just an easier way to do what Tim said).
投稿済み Fri, 01 Mar 2019 07:08:45 GMT 、投稿者 Andreas Ruttkamp
thanks Phil,
all docuware msi´s are removed... the only one which ist shown is the docuware 7.0 installer....
i´ve contacted support and now they have all logfiles and must search ....
it´s tricky ;-)
投稿済み Fri, 01 Mar 2019 07:44:29 GMT 、投稿者 Andreas Ruttkamp
thanks Phil,
it´s tricky ;-)
投稿済み Wed, 13 Mar 2019 20:41:32 GMT 、投稿者 Matthew Trembly Software Support Manager
Run the Microsoft Install/Uninstall repair troubleshooter: https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed
Download and run the Fixit for "Uninstalling" and remove any DocuWare items that are still there after the uninstall (see pic for how they will appear).
