Veröffentlicht Thu, 28 Feb 2019 11:08:16 GMT von Andreas Ruttkamp
I have deinstalled dw 6.12 on an machine and wish to install a fresh dw 7.
But... setup offers only "update" or "deinstall" ... New system isn´t available.
Are there an option to start setup in an "install" mode to install dw 7 anyway ?
Veröffentlicht Thu, 28 Feb 2019 13:19:25 GMT von Casey Miller Director of Technical Services
make sure after the uninstall, that you delete the docuware folders at installation path.
C:\Program Files x86\Docuware
 Also go to %localappdata% and %programdata% and make sure to delete docuware folders in these locations. After this, try running
Veröffentlicht Thu, 28 Feb 2019 17:54:55 GMT von Tim Ohm
Check the windows installer cache for any DocuWare MSIs.  It is a hidden folder, even with 'show hidden folders' enabled, so go there manually - C:\Windows\Installer.  You'll want to add the author and comment columns to find useful files.  It could be something is still stuck ... so right click on the MSIs and choose uninstall.  Not sure if that is the issue, but worth checking.
Veröffentlicht Thu, 28 Feb 2019 18:01:30 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Easiest is to find the Microsoft Installer cleanup tool. I found it a few weeks ago. Run that and remove any DocuWare msi's (just an easier way to do what Tim said).
Veröffentlicht Fri, 01 Mar 2019 07:08:45 GMT von Andreas Ruttkamp
thanks Phil,
all docuware msi´s are removed... the only one which ist shown is the docuware 7.0 installer....
i´ve contacted support and now they have all logfiles and must search ....
it´s tricky ;-)
Veröffentlicht Fri, 01 Mar 2019 07:44:29 GMT von Andreas Ruttkamp
thanks Phil,
it´s tricky ;-)
Veröffentlicht Wed, 13 Mar 2019 20:41:32 GMT von Matthew Trembly Software Support Manager
Run the Microsoft Install/Uninstall repair troubleshooter: https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed
Download and run the Fixit for "Uninstalling" and remove any DocuWare items that are still there after the uninstall (see pic for how they will appear).
