Publicado Wed, 02 May 2018 10:12:03 GMT por Kjetil Kulterud Service Owner
I want to delete several AutoIndex workflows in DW administration (DW Cloud) but I don't have the option to do so anymore.
The option for editing the workflow is also missing.
Any ideas?
https://www.docuware.com/sites/default/files/forums-images/Autoindex%20options%20missing.jpg
Publicado Tue, 12 Jun 2018 12:07:44 GMT por Vincent Bee
I have exactly the same problem. impossible to find a solution
Publicado Tue, 12 Jun 2018 12:29:42 GMT por Phil Robson DocuWare Corporation Senior Director Client Services, Americas
There are 2 possibilities.
1. You are not the user that created the AI workflow. Do you have more than one Administrator?
2. There is a problem in the database. In this case you must open a Support Request so that is can be investigated.
Publicado Wed, 13 Jun 2018 01:14:04 GMT por Matthew Trembly Software Support Manager
In the right-click context menu, select "Start/Stop Workflows" to check your AIX jobs for errors.  Is the AIX job you're trying to delete in an error state?  If so, you need to kick it out of the error state.  Try starting it.  Did the DW user configured the run the AIX job have a password change?  Once you interact with it, it should shake the cobwebs so you can edit or delete it.
Publicado Wed, 13 Jun 2018 07:39:36 GMT por Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Kjetil,
I have exactly the same issue. I currently support 3 cloud environments and in neither I am able to delete Autoindex Workflows, even as the Org Admin. The same applies to Workflows created in Workflow Manager - I can only unpublish the Workflows. I have not yet bothered to open a support request with DW as it is only a minor inconvinience to me - you should probably do that to solve the issue.
Publicado Wed, 10 Oct 2018 18:14:17 GMT por Kim Sims Sr. Solution Integrator
This is what managed to get me some relief from the error state maze. Since I couldn't edit, delete or anything other than start/stop which produced errors continually.
What I did was to 'deactivate' each workflow, start each 'deactivated' workflow and let it complete, which presents a 'success' result(go figure).
Once out of the error state, I edited each one without changing any of the configuration and saved.
Once completed, I activated them again and all was well.
I hope this helps someone else as it is quite an aggravating situation.
Publicado Wed, 13 Feb 2019 14:07:30 GMT por Marc-Antoine Salsedo Developer
I had this issue and I figured out that when you have this kind of issue (cannot delete nor edit / run auto index process) this is mostly because "status" column of dwsystem.dwworkflow table has reached its size limit.
Indeed, this column keeps in XML format each starting time of your AIX (+ time and number of processed records).
So if your process start, let's say, each 5 seconds, your AIX row is updated with one more line in the XML status file.
You cannot start or edit this auto index anymore because the system cannot update the corresponding row in the DB
So the solution is to update the xml value for this autoindex by removing the old unecessary log entries.
Hope this will help someone
