Publicado Thu, 28 Jun 2018 08:34:47 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Let's start with what version of DocuWare you are using and what update was applied?
Publicado Thu, 28 Jun 2018 10:49:50 GMT por Joe Kaufman Bell Laboratories Inc No longer there
Jazz,
Is it perhaps related to this?
https://www.docuware.com/forum/english-forums/docuware-help-technical-problems/export-csv-now-exports-semicolon
If you moved to 6.12, that would be my guess -- the delimiter changed, or at least has the potential to change...
Publicado Mon, 07 Oct 2019 15:26:02 GMT por Darrell Yaw Support Specialist
I can't seem to find the forum topic listed.
Publicado Thu, 28 Apr 2022 20:43:52 GMT por Andrew Koontz Senior Solutions Engineer
Why do all these links in the forums lead back to the DocuWare home page? What's the point of having a forum like this if the links to the results don't work?
Publicado Fri, 29 Apr 2022 07:43:50 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Andrew,<br> <br> about two years ago the forum received a complete rework, including a new design and a new URL structure.<br> All links from before the rework are broken as a result.<br> However, the end of the old URL is the title of the forum post and you might be able to find the post using the title.<br> <br> Hope this helps.&nbsp;<br> <br> Greetings from Germany,<br> Simon H. Hellmann<br> DocuWare System Consultant<br> &nbsp;
