Publicado Tue, 11 Sep 2018 19:08:45 GMT por David Blake Ricoh USA Sr. Solution Integrator
Customer has v 6.10 and claims to need to hit "Edit" and read in the Acrobat Viewer.  Otherwise E sized (33x44) images are not at all readable in the DocuWare viewer.  These are not AutoCad drawings.  They have been scanned and imported into DocuWare.
Publicado Wed, 12 Sep 2018 11:27:45 GMT por Casey Miller Director of Technical Services
This would make sense. I believe the docuware viewer is just an HTML viewer. It is going to try and squeeze the image into the frame. If it is large format, you are going to have to open in an app like you would for some excel, CAD, indesign etc.
Publicado Wed, 12 Sep 2018 11:32:49 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
All documents are rendered to a PNG file for display in the viewer. The viewer does have zoom settings. I am not sure if the page is rendered at 8.5x11 or at it's orginal size. If you zoom in does the zoomed portion become clear and readable?
Publicado Fri, 05 Oct 2018 05:05:38 GMT por Tobias Getz DocuWare GmbH Team Leader Product Management
The DocuWare viewer also uses an image sharpening method which is great for reading text but might be not so great for drawings. It is the magic wand icon in the toolbar in the area "Display". You can toggle this option on and off.
