Publicado Thu, 26 Apr 2018 12:23:49 GMT por John DeLaat
Does admin require a license to configure and run desktop apps on the DocuWare Server?
Publicado Thu, 26 Apr 2018 12:26:00 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Yes.
The same rules apply to the Sytem Administrator as applies to normal user licensing with Desktop Apps, and the Web client.
Publicado Thu, 26 Apr 2018 14:14:24 GMT por Josef Zayats
John,
to run Docuware Configuration without requiring a license, go directly to your settings website (http://yourserver/docuware/settings) - this also works fo Docuware online, just use https://yourcompanyname.docuware.cloud/docuware/settings) - after logging in, you'd be able to configure anything without consuming a connection license. Running Docuware Administration does not need a license.
Running Desktop Apps.(on Docuware server, on stand-alone computer, or conencted to Docuware Online) is not that straightforward: running Docuware Import and Docuware Printer does NOT require a license, but running Connect To Outlook and SmartConnect use a license.
Hope this helps
Publicado Tue, 28 Aug 2018 05:23:50 GMT por Gilles Sauvagnat Altexence
Hi
I need to reopen the post as the new license policy (named license) changes the way to handle administration/maintenance.
I understand that using the configuration tools does not require a license, but once a modification is done one has to test it. Admin user is oftenly used to do so. It means that in the named license world the admin user needs a dedicated license.
This was not the case in the concurrent license world. Consequence a user license has to be sold for maintenance purpose.
Am I right ?
Best regards
Gilles
Question : what's about Workflow designer using the Desktop authentification ? License needed ?
Publicado Tue, 28 Aug 2018 12:32:24 GMT por Simon H. Hellmann Wedderhoff IT GmbH Systemadministrator
Hello Gilles,
the workflow Designer does not consume a license.
If you want to log in to DW to test a newly created configuration, yes, you need a license. You can either assign a license to the admin user, use another user instead of admin for testing, have at least one concurrent user license or switch named licenses around via administration any time you want to  test things.
Those are just the 4 ways of going around that problem which came across my mind now, maybe there are more.
I hope this helps.
